Configure an IS-IS accept policy for a specific I-SID list to represent local or remote Layer 3 VSNs, which allows the system to redistribute the remote VSNs to the VSN where you applied the filter.
If the route policy changes, you must re-apply the IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map to apply.
- Select IS-IS.
- Select the Accept Isid-List tab.
- Select Insert.
- In the Name field, specify the I-SID list name.
- Select enable in the Enable check box to enable the filter.
- In the PolicyName field, specify the route-map name.
- Select Insert.
Accept Isid–List Field Descriptions
Use the data in the following table to use Accept Isid–List tab.
Name |
Description |
Name |
Specifies the name of I-SID list. |
Enable |
Enables or disables the I-SID list entry. The value must be enabled to filter. The default is disabled. |
PolicyName |
Specifies the route policy name. |
BackBonePolicyName |
Specifies the backbone route policy name. |
